Code to initiate call from WebEx app not working with WebEx Intune app
thomas-w
The following code can be used to initiate a call from a bot in the WebEx app:
val intent = Intent(Intent.ACTION_VIEW).apply {
    data = Uri.parse("tel:1234567890")
startActivity(intent)
However, it doesn't work with the WebEx Intune app.
Can anyone tell me what needs to change to make this work with WebEx Intune? Or should this work?
Thomas
Janos Benyovszki
@thomas-w thanks for clarifying. On this forum we mainly help with SDK and API related queries, for generic Webex App questions, you might be better off with contacting TAC here https://www.cisco.com/c/en/us/support/web/tsd-cisco-worldwide-contacts.html .
Janos Benyovszki
@thomas-w can you please specify what Webex SDK you are using? You only mentioned Webex App, but not sure which one this means:
https://developer.webex.com/meeting/docs/sdks/android-sdk-overview
https://developer.webex.com/meeting/docs/sdks/ios-sdk-overview
This is on Android but it's not using the SDK. The code is part of a support chatbot that should give the user the option to call a number through the WebEx Intune app.
