Error 1021
DaniloSilva
Community Member
Hello, When a try call POST to create a report by API  I'm recived the error code 1021 with  this message
API to create https://webexapis.com/v1/reports
    "message": "No body provided to create report with",
    "errors": [
            "errorCode": 1021
    "trackingId": "2529-4eff-bca7-f1dc8f0a9cd6"
For call  I use postman with bearer token  and templetId on body. For get template ID I call api https://webexapis.com/v1/report/templates
Any suggestion  ?
Janos Benyovszki
@DaniloSilva it's difficult to tell what the exact issue is, the server error refers to a body not sent with your request. So this seems to be a possible formatting error. Would you mind also providing the API request that you did? Also, opening a Support Case for this [email protected] might be a better way of handling it, as this seems to be an individual request error. Thanks
