ERROR Invalid value for filter: mentionedPeople
Raghu13
Anyone had success with using webhook to GET messages and filtering on mentionedPeople when the personID is the personID of a webex bot?
All attempts to create a webhook filtered using this >> [email protected] failed with below error:
'Invalid value for filter: mentionedPeople')
 Any guesses on what I might be doing wrong?
Resolved:
dtibbe has just one part of the answer in that the ID starts with Y2lz...
What was missing was the key - you needs to use https://developer.webex.com/docs/api/v1/people/list-people  to find the Bots personID
Raghu13
Thank you for responding to my question!
First to clarify what is personID and BotID. This documentation on Bots goes into the difference between Bots and People states
- people have a personId that must be resolved via /people, while bots have a Bot Id and a personId.
- The Bot Id is shown in the apps page and is usually only known to the developer
- while the bot's personId can be looked up via the bot's email address in /people.
From my Bot developer page, I see the Bot username has a email format [email protected] and the BotID a long string that usually starts with Y2lz....
I have tried creating a webhook using (as below) both IDs and failed.
[email protected]
mentionedPeople=Y2lzY......
I have been successful in creating a webhook when I have used a regular users personID which has narrowed down the issue to failure to when I use a Bot info in the filter.
dtibbe
You've provided the bot's email but you'd need to provide the person id as described at https://developer.webex.com/docs/api/v1/messages/list-messages
Person IDs usually starts with Y2lz...
Resolved:
