Features Hunt Group API Responce
mahendra09
Visitor
When get below error in Hunt Group API
"errorCode": 25055,
"message": "INVALID_COUNTRY_CODE. Missing or invalid default region.",
Body request
    "name": "xxxxxxxxxx",
    "phoneNumber": "xxxxxxxxxx",
    "extension": "xxxx",
    "firstName": "Hakim",
    "lastName": "Smith",
    "callPolicies": {
        "policy": "UNIFORM",
        "waitingEnabled": false,
        "groupBusyEnabled": true,
        "allowMembersToControlGroupBusyEnabled": true,
        "noAnswer": {
             "nextAgentEnabled": false,
             "nextAgentRings": 5,
             "forwardEnabled": false,
             "numberOfRings": 1,
             "destinationVoicemailEnabled": false
        "busyRedirect": {
            "enabled": true,
            "destination": "xxxxxxxxxx",
            "destinationVoicemailEnabled": true
        "businessContinuityRedirect": {
            "enabled": true,
        "businessContinuity": {
            "enabled": false,
    "agents": [
        {"id": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxWI"},
        {"id": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxYg"},
        {"id": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx9t"}],
    "enabled": true,
    "huntGroupCallerIdForOutgoingCallsEnabled": true
Janos Benyovszki
@mahendra09 the error refers to an incorrect country code, but it is hard to verify what you have used as it is blanked out. If you are sure that the country code is correct, you can open a Developer Support case - email to [email protected] - and we will look into it.
Janos Benyovszki
@mahendra09 you misspelled the email address. It's [email protected] , not [email protected]
mahendra09
Visitor
not email answer [email protected]
Janos Benyovszki
