how to get subscription info with api?
proster12
Frequent Visitor
Frequent Visitor
hi~!
I want subscription info using api.
subscription name, expiry date, status, etc...
I couldn`t find it on the developer site.
Is there a way?
Tnank you.
5 Replies 5
dwynn2
Community Member
I currently have a project for the same request.  When would this data be available through the API?
We're not aware of any plans to implement this. As mentioned below, all we have is the List Licenses, which provides some subscription data. If that's not sufficient, then an idea will need to be created on https://ciscocollabcustomer.ideas.aha.io/.
Raffaele Lagana
If you're looking for license subscriptions, the only API that provides anything related to these is the /list-licenses API. This mainly only provide Subscription names though, no details for status or expiry dates. You can request those as a new feature here if you wish.
Thank you for answer.
I would like you to create an API that also provides subscription information.^^
Thank you.
The only API we have for basic subscription details (mainly just Name) is the /licenses API as mentioned. If this is not sufficient, then please create an idea on https://ciscocollabcustomer.ideas.aha.io/. Product Management can then assess and provide feedback there as time allows.
