Meeting registrant
Patience Umoru
Hi there. Is there a way to update a meeting with registrant through Webex API? Even if I get a meeting through API and then send it as a body for an update call I get the message "Registration update is rejected because the registrant has already registered."
Patience Umoru
Thank you for reaching out. With regards to being able to update a meeting you would first need to delete all registrants in order to edit the meeting. It does not allow you to edit the meeting while registrants are present so this would need to be a feature request.
https://ciscocollabcustomer.ideas.aha.io/  Thank you
