Not finding imiconnect docs in webex developer portal
sandiban
Query from @[email protected] in #webex4devs space
hi, nowdays I am not able to find the imiconnect docs in webex developer portal.
Do am I missing something here?
sandiban
Hi Nitesh,
This should help here - https://developer.webex.com/docs/imiconnect
Please let us know for any further details.
Thanks!
Sandip
Any specific reason it is not showing in the Webex dev portal?
Hi @nitesh.upadhyay
Currently, I'm not exactly sure under which section, it's been placed.
However, in the Developer Portal search box, if you try to search with "imiconnect", it should give you the result.
So basically it's still lying under the Developer Portal only.
