Locate Webex APIs
Chris Deren
I am looking to configure following features via webex APIs which I cannot locate in the documentation.  I wanted to ask the experts here if these are available and I am just not seeing them or if they are not available yet, and if so is there a timeline when these will become available:
  • Outgoing user permissions Authorization Codes and Auto-transfer numbers
  • Hoteling functionality for workspaces
  • Emergency Call Back Number
  • Workspace Number Updates
Jeff Marshall
You can modify a user's outgoing permissions via https://developer.webex.com/docs/api/v1/webex-calling-person-settings/modify-a-person's-outgoing-calling-permissions-settings
You can only GET details, https://developer.webex.com/docs/api/v1/webex-calling-workspace-settings-with-numbers, no way currently to change via the API. You can configure hoteling for a person though, https://developer.webex.com/docs/api/v1/webex-calling-person-settings/configure-hoteling-settings-for-a-person.
This can not be set via the APIs at this time.
This can not be done via the API at this time.
If you'd like you can submit feature requests via https://ciscocollabcustomer.ideas.aha.io/
Thank you @Jeff Marshall
>> I am aware of this API, but it does not include Authorization Codes or Auto-transfer numbers
>> This is kind of important feature if using hoteling as the workspace needs to enabled for the user to be able to login to it. Hopefully this is coming soon
Raffaele Lagana
I believe none of those features are currently available, they'd need to be requested for and that can be done here: https://ciscocollabcustomer.ideas.aha.io/
