Personal Access Token
Patience Umoru
 Where Can I generate my personal access token to explore the webex APIs?
Patience Umoru
Your personal access token can be pulled from the developer portal's Getting Started page after you've logged into the portal. But keep in mind it only lasts for 12 hours.
But if you want a long lasting token then you would need to create an  Integration to get an Oauth access token.
