Query regarding Webex App SDK and Browser SDK
sandiban
Query from @chuck Shipman at #webex4devs space
Can the Webex Embedded Apps SDK and the Standard Webex SDK be used in the same JS Front-end app simultaneously? Or does it have to be split between front-end and back-end?
sandiban
Hi Chuck,
If I understand your query correctly, then I'd say - App SDK functionalities can be used/embedded to the Android App and iOS Apps based on the SDK you're using/referring to and JS SDK features can be embedded in the websites!
When you say Standard JS SDK, I hope you're referring to Browser SDK.
However with further clarity, we can try to help you better.
Thanks!
Sandip
