"Device has not registered as an XAPI provider"
aalejo
Level 5
Level 5
When sending and API request to a device over webex hub api i am getting response "Device has not registered as an XAPI provider".
I am able to get device id using webex api but other webex api request are getting this response..
Janos Benyovszki
@aalejo if you're getting that error it might be an issue with the device itself. If you Get Device Details it should show if it has xapi capabilities or not and what type of device it is. Please check that.
Hey Janos
I was able to find issues: by mistakes i was sending REST command to the board's pad instead of the board itself. lol . Of course pad does not register itself as a xapi device.
Alex
