SSO configuration
OHua
Community Member
Hi, Team
after setting SSO step by step in article (https://help.webex.com/en-us/article/ubrigo/Configure-single-sign-on-in-Control-Hub-with-SimpleSAML)
First, I have a full admin account (assume [email protected]) in Control Hub
when I set SSO configure in Control Hub, then I can't login into Control Hub by [email protected]
cause login redirect to identity provider, and identity provider doesn't has [email protected] account
I have tried create [email protected] account into identity provider, let me login
but after login success, redirect to webex, I get the error "do not have a Webex account privilege"
if SSO settings effect Control Hub login rule
how can i manage Control Hub after SSO configuration ?
I'm also read article (https://help.webex.com/en-us/article/g2wy83/Configure-Single-Sign-On-(SSO)-Authentication-for-Attendees-for-Your-Cisco-Webex-Site)
But I can't find "Auto Account Creation" button/option in Control Hub
Is there a full detail practice for SSO configuration ?
sandiban
Hi @OHua,
Could check with our TAC team on this since this is related to Control Hub setup.
You can reach out to them over here
From the provided description, quick thought from my side - did you created this User [email protected] as a Sandbox account?
If not, I'm afraid how can you login to Control Hub with it.
I can suggest to create a Developer Sandbox Account first from here - https://developer.webex.com/docs/developer-sandbox-guide
If you're looking forward to create a Webex Developer sandbox account from Webex portal, make sure you use the email id which is still no way associated with any Webex or, Control Hub account.
Like your mail address can be - [email protected] which I don't think associated with Webex so far.
Let us know for any further details.
Thank you!
Sandip
