summarize API
demule
Do we have summarize API to conclude webex thread
demule
One more query
How can I get message thread, I mean all the replies to particular message via API.
As there is no direct API resource for that, I believe you would need to download all messages - i.e. back to the date/time of the thread's "root/parent" message - and check if the parentId value is equal to the root/parent message.
Janos Benyovszki
@demule we do not have that unfortunately. You can suggest it here https://ciscocollabcustomer.ideas.aha.io/ so that other users can support the idea, which would help Product Management prioritise it for the future. Thanks
Sure, thanks.
