Webex API Remote Access Reports
m.sheldon
Community Member
I'm using the XML API and I'm looking for a way to pull Remote Access session information. I tried all the history service endpoints but ended up with zero results for all
https://developer.cisco.com/docs/webex-xml-api-reference-guide/#!history-service/history-service
I can pull it up through the site administration web interface under Reports > Remote Access > CSR Report. But is this possible through the API?
Janos Benyovszki
@m.sheldon this might be coming a bit late, but there is no Remote Access XML API, I am afraid. Also just to note, the XML API is being deprecated in favour of the REST APIs as mentioned here . If you are still with Webex, you can head over to the Dev Portal and find out more about the new Meetings REST APIs .
