Webex API script token admin rights
32freddy
Community Member
I created a script to read user license details from the webex API, but right now it only uses my personal token which expires after 12h.
How can I get a permanent token? I tried creating a bot, but it does not have permission to read licenses from the API.
Thanks!
dtibbe
You need to create an integration as described at https://developer.webex.com/docs/integrations
Your user has to run the OAuth flow at least once, after that you may use the refresh token to extend the access token's lifetime.
32freddy
Community Member
Thank you, I'am going to try that.
