Webex bot failed to send message
rodneymuyanja
Community Member
Hi, I'm developing my first webex bot but i keep getting the following response when the i call the message endpoint https://webexapis.com/v1/messages
  "message": "Message destination could not be determined. Provide only one destination in the roomId, toPersonEmail, or toPersonId field",
  "trackingId": "WEBEX-DEV-PORTAL_50b497fa-dbb6-4ed0-8fe4-0f5e184c0365_5"
may be i need more details on what the message means because i have provided the necessary fields for my request shown below
  "roomId": "Y2lzY29zcGFyazovL3VybjpURUFNOmV1LWNlbnRyYWwtMV9rL1JPT00vOWNlYmM4MDAtMGYzMy0xMWVkLTk4ZDMtOTM5Yzg5MGZmYzgw",
  "parentId": "Y2lzY29zcGFyazovL3VybjpURUFNOmV1LWNlbnRyYWwtMV9rL01FU1NBR0UvYzI5NzVlODAtMTAwZS0xMWVkLTk4OGMtOWQ3OGY2YWFmYTM5",
  "toPersonEmail": "[email protected]",
  "text": "Hi, not cool that you don't greet",
  "toPersonId": "Y2lzY29zcGFyazovL3VzL1BFT1BMRS9iYjI5NWNlYS0zNTMzLTRkMDAtYTE1MC0yMTc2ZDRiZGU5MDQ"
any help and direction provided would  be highly appreciated.
rodneymuyanja
Community Member
Thank you very much for this
dtibbe
The reason is quite clear if you check the error message: you have provided all, roomId, toPersonEmail, and toPersonId. The endpoint accepts only one of them to be set.
Simply remove toPersonEmail and toPersonId and try again.
