Webex Contact Center; Webexconnect; HTTP node; Http POST fail MS API
jbroderick@holycross.com
Frequent Visitor
Frequent Visitor
I am building a chat that translates between Spanish and English.  I am using Azure AI (Microsoft language) API.  I am using the command 'detect'.  When I call the initial post my flow fails.  If I test this node within the flow I get the desired result.  If I run the code within my IDE I get the desired result.  Are there any examples with the HTTP node executing a Post?  (I have only found get examples.)
Janos Benyovszki
[email protected] not sure which sample you have found, the one I am aware of is https://www.cisco.com/c/en/us/support/docs/contact-center/webex-contact-center/217735-configure-http-request-on-call-flows-wit.html . This also talks about GET but gives a good description about usage. Have you seen that one?
Thank you Janos,
The flow development kit for call flows in WxCC is different than the one used for multi-media flows such as chat.  That tool is Connect.imi   It is that HTTP node that I am trying to use.   I do believe the problem may be due more to the fact that I am developing from a copy and their is a setting that has to be cleaned up when making copies; not so much the http node.
However, if you do have access to more examples of chat flows in connect.imi I would be interested in those links.
Thank you,
Jennifer
Just came across this post so thought to add that we have a really good Lab learning on Connect and its Flows, see here: Lab 12 - Digital Channels · Labs Library. Might be of use to you.
