Webex Interface Distortion by Connect/Disconnect External Monitor
Wissam-Maarouf
I'd like to report a recurring issue with the Webex application. When I connect or disconnect my laptop from an external display (such as a projector or monitor) while Webex is running, the application interface becomes unstable. The screen begins to flicker, and the Webex UI becomes distorted—showing black blocks, misaligned borders, and graphical glitches.
The only workaround I've found is to completely close Webex before connecting or disconnecting the external screen. Once reopened, the application functions normally without any visual issues.
It would be great if this could be investigated and resolved in a future update.
Thank you for your support.
Best regards,
Wissam-Maarouf
Version: 45.6.1.32593
