Showing results forĀ
Search instead forĀ
Did you mean:Ā
Webex Publish API not formatting text
dhisinha
Webex Publish API not formatting text. When we send data : "<b>Hi</b>"
It is just publishing same as this  <b>Hi</b>, not Hi
dstaudt
Are you referring to the Create a Message operation? https://developer.webex.com/docs/api/v1/messages/create-a-message
If so, if you send your example markup in the html key (or even the markdown key, but not the text key) of the POST body, it should be displayed as expected:
POST https://webexapis.com/v1/messages
  "roomId": "Y2lzY29zcGFyazovL3VredactedzNjRkMGUx",
  "html": "this is <b>bold</b> text"
