WebexAPI /access_token endpoint responds with code 200 and empty body
MaksymRossiitsev
Frequent Visitor
Frequent Visitor
Greetings,
I'm working on an application, based of off the Webex Integration app. After all the permissions are set, I accept the app permissions, and receive the code. Then, whenever and however I try to generate the access token using https://webexapis.com/v1/access_token endpoint - I always get empty body and code 200.
First I thought that the app must be approved by the tenant admin, so I tried that and the result was the same.
POST https://webexapis.com/v1/access_token
Content-Type: application/x-www-form-urlencoded
grant_type=authorization_code&code=MDU4NGM4MzYtZTE1OC00MT.....-fdbc6ba3e2ed&client_id=Cad24deae5c65c524.....b39f13b97ea49&client_secret=b2b10a022102d176....862490ce43faaacf0e&redirect_url=https://website.com
 Here's tracking ID for the reference: ROUTERGW_a5d6898b-cb5e-45b1-b6f9-0884fe742a3b
What is it that I may be doing wrong here?
Thank you
Thanks for checking back @MaksymRossiitsev!
Yes, looks like the problem here is - you're using the property name "redirect_url" in place of "redirect_uri".
Kindly change that property name to "redirect_uri" and thing should actually start working fine.
Let us know how it goes.
Regards!
Sandip
Please Note: If you think the solution provided above was helpful and satisfactory, please accept it as a Solution! However if you want to discuss it further and get yourself unblocked, please don't hesitate to reply back on this thread and we'll try to answer those queries by the soonest. In that case, once all of your queries are cleared - finally you can mark it as "Accepted as Solution"
5 Replies 5
MaksymRossiitsev
Frequent Visitor
Frequent Visitor
Hello @sandiban , thank you so much for the reply!
So, I've tried cleaning up the cookies, but still get pretty much the same result.
Attached the headers screenshot below, if it can be any useful.
TrackingId: NA_572cf3f5-e3bf-4fac-b850-546d7dca6763
Thank you!
Regards!
Sandip
Yes, this is it!
My bad, sorry for taking your time with this, should've paid closer attention to the property names
Now it works, thank you!
No problem at all @MaksymRossiitsev, it happens sometimes even with us!
Glad to hear it's working fine now. Please let us know for any further assistance going ahead.
Regards!
Sandip
sandiban
Hello @MaksymRossiitsev,
Thanks for your patience so far!
Honestly, I don't think you're doing anything wrong here however I believe it's just the backend exception due to which there was no Response even though the Response status_code was 200.
Could you kindly try to pull the Token details from POSTMAN once following the attached screenshot here and check how it shows.
If still you face the same problem, then kindly clear the Cookies by hitting 'Cookies' button in POSTMAN and then try again.
Hopefully that should resolve the problem, let us know how it goes.
If you continue to face the same problem, then kindly share us the latest trackingId and we can check further with our backend team.
Regards!
Sandip
