webhook roomId filter
Jose Monzon
Community Member
When creating a webhook for message resources, it is possible to filter by roomId. However it is limited to only one roomId. Is there any way to filter by more than one roomId?
Raffaele Lagana
Not possible at the moment. Only option is to not enter a roomId filter which will then allow the webhook to get triggered every time a message event occurs in any room/space that the webhook creator is in. Not sure if that helps your use case.
