08-12-2021 03:03 AM
What are the requirements of Webex education connector?
I have a client who is building a web application that serves the purpose of LMS .
Now how can I integrate the Webex education connector with it?
Right now they are doing the integration with Webex using REST APIs and SDK but I want to integrate Webex education connector to provide a right out of the box solution. So how can I do this?
What are the requirements or specifications which should be present in LMS to integrate?
08-12-2021 09:09 AM
The Webex Education Connector integrates into LMS using the LTI standard.
This allows the LMS to kind of embed the Education Connector and provide to it the context of the course.
If your customer is interested in this kind of integration the should look at developing the LTI interface - you can find a lot of material on that - this one is probably a good introductory read: https://www.imsglobal.org/basic-overview-how-lti-works
08-12-2021 03:46 AM
Have a look on the Webex Help, there are plenty of documents regarding the connector: https://help.webex.com/result/education%20connector/%5B%5D?offset=10&order=Relevance
Which LMS are you using?
The FAQ is probably a good point to start at https://help.webex.com/n0supij/
