cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
6
ÚTIL
6
Respuestas
Webex Contact Center Technical Partner Summit 2023
There is posted a Webex Contact Center Technical Partner Summit for 2023.  Per outline a lot of info looking for but it list as Cisco office Richardson, TX and "limited seating" - sounds to reflect as local only, but no other locations offered.   Are there any plans to expand Webex Contact Center Technical Partner Summit for 2023 beyond Richardson, TX?  Is there a way to at least get copy of the power point presentation for those unable to attend locally to Richardson, TX?
1 SOLUCIÓN ACEPTADA
6 RESPUESTAS 6
MapleLeaf
The recordings are on the sharepoint site, but i have not been able to find the slide decks. Does anyone know if these are going to be posted?
Hi MapleLeaf - what is the link to the sharepoint site?
Thanks MapleLeaf - awkwardly looks as though the recordings require a password and login attempts fail with standard Webex ID usr/pwd.   Definitely looks to be the right spot.  I will try again periodically to see if access issue gets resovled.
The site now contains per password access to each recording.   MapleLeaf's link was the right solution.  Much Obliged!
John Steele
Ask your PSM to get you added to the Team space when it starts.  You won't be able to attend remotely or listen in but you can get the content you need in the space.
