2 questions
1 how can I sort my contacts by surname and not by name ? 2 Why is not possible keep the status more then 7 days ?
JOSEPHMOELLER
Looks like you can only sort by name.
Not sure what you are referring to by "keep the status" do you mean when it says "set a status"    If that is what you mean, then 7 days is all webex currently allows.
You could put in a feature request to Cisco to do this.
You can also check out webex's beta program.
here's the link to Customer Connection - Cisco Community
