Bookmark
Subscribe
963
Choose a status setting not keeping recently used settings
JimmyL
When setting status, in the "Choose a status" section, there are usually some of the custom statuses that I've used recently, including the icon I put with them. But they frequently get overwritten by default statuses that I have never used once, like "Traveling for business" or "Working from home", forcing me to go back and redefine a custom status and add a custom icon.
I've probably had to redefine my custom status more than a hundred times since I started using Webex. This is very annoying and poor software design. Why not just keep the last five most recently used statuses? Why try to force me to use the precanned ones?
dtibbe
Product enhancement ideas can be suggested and upvoted via https://ciscocollabcustomer.ideas.aha.io/
Product management reviews that aha but not this board
dtibbe
Thanks dtibbe. I'd tried submitting a feature request before with a link I had but kept getting errors submitting it. That link worked fine and I got the suggested submitted.
