10-27-2020 06:25 AM
I see where the free version of Webex allows for international calls for up to 50 minutes.
If you have a paid subscription, do the same rules apply that work when using Webex domestically?
Solved! Go to Solution.
10-29-2020 08:06 AM
@Paul.Kingsman , just to be sure: are you using Webex Meetings or Webex Teams?
With Webex Meetings you will still be able to organize/join meetings with users who are in the US. It gives you the possibility to have virtual meetings with anybody, irrespective of your/their location. For the audio part you can just use your PC (VoIP) or use the Webex dial-in number of the country you are located (if available, and if enabled by your administrator).
With Webex Teams you can continue to make audio & video calls with other persons, irrespective of your/their location.
10-29-2020 08:06 AM
10-29-2020 09:11 AM
10-28-2020 01:47 AM
@Paul.Kingsman , can you clarify what you mean with "free version of Webex allows for international calls for up to 50 minutes"? Is this something you have read on the Webex site?
With the free Webex version the only audio option is VoIP.
10-29-2020 06:55 AM
