Is there a way to integrate Grammarly with Web-ex
sandfed@cisco.com
I use Grammarly and it saves me from countless typos and other mistakes. It would be very nice if it worked within webex. Is there a way to allow it to function?
Your suggestion was half helpful. As I mentioned I already had Grammarly installed. As so many of our applications are web-based, I did not realize I only had it installed for Firefox. I went ahead and installed the MAC version as your suggestion mentioned and finally, I can use the tool with Web-ex.
5 Replies 5
Vaijanath Sonvane
sandfed@cisco.com, glad that your issue is resolved.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Vaijanath Sonvane
Hi sandfed@cisco.com ,
To access Grammarly in most native apps, please install Grammarly for Windows or Grammarly for Mac. You will also see Grammarly’s suggestions across a wide array of websites.
I am a new hire and would like to know if Grammar;y is approved by Cisco? I see that you all are using it, but just wanted to double check.
I already have it installed and works with most stuff (email, word…) but it does NOT trigger in Webex.
