Markdown: Code Block without Line Numbering
machtschnell
Community Member
Markdown supports a code block:
  1. With line numbering
  2. Without line numbering
  3. Starting line numbering at a specific number
My attempts in Webex to have a code block not use line numbering or start at a specific line number are not working. Does anyone know how to make this work?
Thank you.
AFAIK this is not possible. There are no options in the markdown section in the Webex app for any of what you ask about.
Response Signature
What about manual markdown input, such as:
```python (options)
aoeu
aoeu
aoeu
The "(options)" would be specifying no lines. I can't find the syntax for that. Is Webex open source so I can search the source code for the syntax?
As Roger said, there are no options for markdown blocks.
Webex is not open source.
