06-22-2022 09:37 AM
When i need to change a date or / hour on the webex meeting Thant i created. The webex create more links, and change my official link !
06-23-2022 11:44 AM
Were you able to click each link and ensure it takes you to the same meeting? Since this is with Meetings and not Webinar, I've not seen this issue before, so want to ensure you're good. If not, at this point, I'd recommend opening a TAC case to confirm, as it does seem odd to me.
06-23-2022 02:35 AM
It's for a meeting not a Webex webinar.
15 days ago it worked very well, with the automatic link between date and time changes.
But since 15 days it does not work anymore.
Thank you for finding the problem. Good resolution.
Regards, Christine
06-22-2022 02:10 PM
@Christine G How are you scheduling and modifying the meeting - via Web UI or Outlook? Is this for a regular meeting or an event? If the Web UI and Events, are you using modern view or classic view?
06-22-2022 02:29 PM
06-22-2022 04:14 PM
06-22-2022 06:03 PM
@Christine G , the reason I'm asking is because this is a known issue when scheduling a meeting via the Web scheduler using the CLASSIC interface for Events. The attendee links will change, but if you try to access the meeting with the old link or the new link you will land in the same meeting. I've opened a TAC case on this previously because our exec admin team noted and worried about the same thing. However, you should not see this using the modern view scheduler.
