Proxy settings
rosdec
Hello everybody,
I'm struggling with my proxy settings in Webex Teams client on Windows.
When I work from the enterprise network I must use a proxy while when I work at home I don't. I need a way to let Webex Teams to switch from proxy settings on and off: when I install it, on the first run it ask me for proxy settings that are written in some obscure configuration file; since that moment I'm not able to remove such configurations anymore and for this reason I'm not able to connect from home where the proxy is not reachable.
Tried to look for some information on the forum with no luck.
Where are the proxy settings stored and how can I modify it on the fly whenever I need to?
Thanks in advance,
Rosario
shockocisco
I have the same ask? In fact on my corporate network we still want to ignore the proxy for all traffic that comes form the client. Use of a PAC file if fine but unnecessary IMO. The client should support a proxy/no proxy configuration independently.
Ssan92
I think Webex takes proxy setting from System or from IE browser as per my experience . It would be really helpful if there was an option to add proxy ip/port within webex app to turn it on or off .
