Re: Webex linux client application not opening.
abhi123
I downloaded and installed Webex linux app on my redhat laptop. But the app is not opening when I try to open it/click on the webex icon.
It is just not doing anything.
Any one experienced this??
Is webex client using Java or python(pyqt) etc. Just thinking if any of these causing it.
Any help is appreciated.
Thank you
Abhilash
16 Replies 16
niranjan1989
This helped me on the Ubuntu 22.04
sudo apt-get install apparmor-utils
sudo aa-complain unprivileged_userns
sudo systemctl stop apparmor
sudo systemcttl start apparmor
Under Ubuntu 22, there are 2 problems with the Webex client by Cisco:
1) The app uses sandboxing via user namespaces. This is blocked by app armor by default under older kernels, as it adds a potential attack surface.
2) The app does not seem to set its LIBRARY_PATH correctly on installation, or rather it does not install libraries into standard locations.
The suggestion here solves problem 1), by re-configuring app-armor to only log (instead of block) the usage of user namespaces. This has security implications. The recommended way would be to update to a later kernel, where app armor imposes less restrictions by default. Whether this is possible depends on available kernels for your distribution, of course.
This suggestion does not solve problem 2. If you start Webex via command line instead of clicking the icon in the GUI, you will see the error messages that remain. When running /opt/Webex/bin/CiscoCollabHost, I got error: Trace/breakpoint trap (core dumped). This is because of the runtime libraries it requires (you can see them by running ldd /opt/Webex/bin/CiscoCollabHost). The solution for this is to set the LD_LIBRARY_PATH to where it keeps them when running the app:
LD_LIBRARY_PATH=/opt/Webex/lib:/opt/Webex/bin /opt/Webex/bin/CiscoCollabHost
Then you will have the thing running.
Yes, this works for me on Ubuntu 24.04.2 LTS
terstegge
Ashley.Sommer
I too am having this problem. After entering my email address, I get redirected to my company's login page, but I just see a blank white page, and cannot log in.
My logs don't show any obvious problem, no certificate errors or proxy issues. The only thing I think it might be is this:
2021-12-06T21:38:09.977Z <Debug> [140069462734592] Browser.cpp:858 OnLoadStart:Browser navigation starting: NativeWebAuthenticationWidget NativeWebAuthenticationWidget 906f
2021-12-06T21:38:09.982Z <Debug> [140069462734592] Browser.cpp:869 OnLoadEnd:Browser navigation ending: NativeWebAuthenticationWidget NativeWebAuthenticationWidget 906f httpStatusCode: 401
It gets a 401 response when redirecting to my company's auth page. I don't know where to go from here.
In my case it was due to the enabled vpn connection.
Thanks. I tested it with the VPN disabled, and yep, it works now. This is still an issue however, because my organisation requires us to be on the VPN at all times when using a work laptop, especially when signing into federated login, with work credentials, like this.
It does work to disable the VPN, sign into Webex Desktop app, then re-enable the VPN, but I'd prefer to not have to do that.
I have similar issue on linux(ubuntu 20.04): I enter my email and see a white screen.
checked with ldd, libraries are installed.
This is a log from my machine:
2021-11-16T07:53:27.159Z <Debug> [140511994177280] HttpRequestManager.cpp:1718 httpRestRequest:{"id":"Making HTTP request","uri":"https://u2c-a.wbx2.com/","method":"GET","action":"/u2c/api/v1/signin/catalog?format=hostmap&mode=extended&emailhash=1295f12c4debd33f24bb94f7503d593e6641b94648465e2d8c877722669f8866&domainhash=56fb2cc1c3afee734c6175cfb71b1cc18e433d8e762fa7685903982415275784","defaultUrl":"https://u2c-a.wbx2.com","currentUrl":"https://u2c-a.wbx2.com/","retryable":false,"trackingId":"CLIENT_eacac5c8-7340-44dc-8b1e-f0fe7e08afd3","cancellationId":"3eeb1eaf-8efe-4230-a339-2e1ecdd8e87a"}
2021-11-16T07:53:27.159Z <Error> [140511985784576] FeatureSettingsManager.cpp:395 getSetting:Attempting to read value from DB before config store has been read. Key: local-user-dir-sync-enabled
2021-11-16T07:53:27.159Z <Info> [140511985784576] CoreFramework.cpp:113 forEachServiceUntilDone:name = onNetworkEventHappened: UserAuthenticated,TelemetryService
2021-11-16T07:53:27.159Z <Debug> [140511985784576] DevicePairRouterViewModel.cpp:144 onPairingStateUpdated:currentPairScene = 0, deviceConnectionState = 0, interactiveIssueMessage = 0
2021-11-16T07:53:27.159Z <Debug> [140511985784576] NetworkStateMachine.cpp:108 onNetworkStatusChanged:NetworkStateMachine - onNetworkStatusChanged UserAuthenticated
2021-11-16T07:53:27.159Z <Debug> [140511985784576] StateMachine.h:106 _handleEvent:ConnectivityStateMachine::Network - Unexpected event {UserAuthenticated} for state [NoNetwork]
2021-11-16T07:53:27.159Z <Debug> [140511985784576] StateMachine.h:119 _handleEvent:ConnectivityStateMachine::Authentication - UserNotAuthenticated -> UserAuthenticated : {UserAuthenticated}
2021-11-16T07:53:27.159Z <Debug> [140511985784576] ServicesStateMachine.cpp:130 deriveNewState:ConnectivityStateMachine::Services [MercuryState:Connected] + [AuthState:UserAuthenticated] == [NewServicesState:Connected]
2021-11-16T07:53:27.159Z <Debug> [140511985784576] StateMachine.h:106 _handleEvent:ConnectivityStateMachine::Services - Unexpected event {Connected} for state [Connected]
2021-11-16T07:53:27.159Z <Debug> [140511985784576] NetworkManager.cpp:1052 onNetworkEventHappened:Network event happened: UserAuthenticated
2021-11-16T07:53:27.159Z <Debug> [140511398590208] ProxyManager.cpp:165 _getWebProxyAddressFromPlatform:About to request proxy for address for the probe address
2021-11-16T07:53:27.159Z <Debug> [140511398590208] ProxyUtils.cpp:136 getSystemProxyInfo:Proxy: Type: Unknown. HostName: . Port: 8080
2021-11-16T07:53:27.159Z <Debug> [140511398590208] ProxyUtils.cpp:143 getSystemProxyInfo:systemProxyAddresses count: 0
2021-11-16T07:53:27.160Z <Debug> [140511398590208] ProxyCallbackManager.cpp:15 getStatusForProxy:Found default proxy:
2021-11-16T07:53:27.160Z <Debug> [140511398590208] HttpRequestManager.cpp:2560 createOutstandingRequest:requestId: 3eeb1eaf-8efe-4230-a339-2e1ecdd8e87a, Outstanding HTTP requests: 1
2021-11-16T07:53:27.982Z <Debug> [140511985784576] HttpRequestManager.cpp:1816 operator():{"id":"HTTP request succeeded.","uri":"https://u2c-a.wbx2.com/","method":"GET","action":"/u2c/api/v1/signin/catalog?format=hostmap&mode=extended&emailhash=1295f12c4debd33f24bb94f7503d593e6641b94648465e2d8c877722669f8866&domainhash=56fb2cc1c3afee734c6175cfb71b1cc18e433d8e762fa7685903982415275784","defaultUrl":"https://u2c-a.wbx2.com","currentUrl":"https://u2c-a.wbx2.com/","retryable":false,"trackingId":"CLIENT_eacac5c8-7340-44dc-8b1e-f0fe7e08afd3","cancellationId":"3eeb1eaf-8efe-4230-a339-2e1ecdd8e87a","networkTimings":[50,151,209,1]}
2021-11-16T07:53:27.982Z <Debug> [140511985784576] OnboardManager.cpp:942 handleCheckIfUserActivatedResponse:[Login] User exists and has successfully activated. For Jabber Client: Teams on jabber is enabled and the contact migration is complete.
2021-11-16T07:53:27.983Z <Debug> [140511985784576] AuthenticationManager.cpp:608 getAuthorizationUrl:[Login] Sending code challenge
2021-11-16T07:53:27.983Z <Error> [140511985784576] FeatureSettingsManager.cpp:395 getSetting:Attempting to read value from DB before config store has been read. Key: UsersChannel
2021-11-16T07:53:27.983Z <Debug> [140511985784576] HttpRequestManager.cpp:1718 httpRestRequest:{"id":"Making HTTP request","uri":"https://metrics-a.wbx2.com/","method":"POST","action":"/metrics/api/v1/clientmetrics-prelogin","defaultUrl":"https://metrics-a.wbx2.com","currentUrl":"https://metrics-a.wbx2.com/","retryable":false,"trackingId":"CLIENT_67cde1d0-ec2d-4002-b210-2e3a997d32ae","cancellationId":"67834457-25d7-4d80-b4c7-d8669b3911ca"}
2021-11-16T07:53:27.983Z <Debug> [140511985784576] HttpRequestManager.cpp:2560 createOutstandingRequest:requestId: 67834457-25d7-4d80-b4c7-d8669b3911ca, Outstanding HTTP requests: 2
2021-11-16T07:53:27.983Z <Error> [140511985784576] FeatureSettingsManager.cpp:395 getSetting:Attempting to read value from DB before config store has been read. Key: IS_FEDRAMP
2021-11-16T07:53:27.983Z <Debug> [140514400745280] LoginScreen.cpp:62 operator():Login model Changed.
2021-11-16T07:53:27.983Z <Debug> [140511985784576] HttpRequestManager.cpp:2600 _removeOutstandingRequest:requestId: 3eeb1eaf-8efe-4230-a339-2e1ecdd8e87a, Outstanding HTTP requests: 1
2021-11-16T07:53:27.984Z <Debug> [140514400745280] BrowserFactory.cpp:58 buildCefBrowser:Building browser NativeWebAuthenticationWidget, instance NativeWebAuthenticationWidget, creating cookie store: 0
2021-11-16T07:53:27.990Z <Error> [140514400745280] FeatureSettingsManager.cpp:395 getSetting:Attempting to read value from DB before config store has been read. Key: windows-new-cef-focus-activation
2021-11-16T07:53:27.990Z <Error> [140514400745280] FeatureSettingsManager.cpp:395 getSetting:Attempting to read value from DB before config store has been read. Key: windows-edge-webview2
2021-11-16T07:53:27.991Z <Debug> [140513344747264] Browser.cpp:261 initializeBrowser:Initing browser: NativeWebAuthenticationWidget NativeWebAuthenticationWidget 9f44
2021-11-16T07:53:27.991Z <Error> [140513344747264] FeatureSettingsManager.cpp:395 getSetting:Attempting to read value from DB before config store has been read. Key: desktop-use-scf-network-stack
2021-11-16T07:53:27.991Z <Error> [140514400745280] FeatureSettingsManager.cpp:395 getSetting:Attempting to read value from DB before config store has been read. Key: UsersChannel
2021-11-16T07:53:27.991Z <Debug> [140514400745280] TelemetryService.cpp:394 sendPreLoginEventsToAdapter:There is already an outstanding prelogin telemetry request. Caching Ob Viewed Enter Password event.
2021-11-16T07:53:27.991Z <Debug> [140514400745280] LoginScreen.cpp:321 showSSOView:Displaying SSO login page.
2021-11-16T07:53:27.992Z <Debug> [140514400745280] AuthenticationManager.cpp:608 getAuthorizationUrl:[Login] Sending code challenge
2021-11-16T07:53:27.992Z <Debug> [140514400745280] NativeWebAuthenticationWidget.cpp:106 navigate:Nav
2021-11-16T07:53:28.005Z <Debug> [140513344747264] Browser.cpp:685 OnBrowserCreated:Browser created: NativeWebAuthenticationWidget NativeWebAuthenticationWidget 9f44
2021-11-16T07:53:28.005Z <Debug> [140514400745280] NativeWebAuthenticationWidget.cpp:106 navigate:Nav
2021-11-16T07:53:28.694Z <Debug> [140510316455680] HttpRequestManager.cpp:1816 operator():{"id":"HTTP request succeeded.","uri":"https://metrics-a.wbx2.com/","method":"POST","action":"/metrics/api/v1/clientmetrics-prelogin","defaultUrl":"https://metrics-a.wbx2.com","currentUrl":"https://metrics-a.wbx2.com/","retryable":false,"trackingId":"CLIENT_67cde1d0-ec2d-4002-b210-2e3a997d32ae","cancellationId":"67834457-25d7-4d80-b4c7-d8669b3911ca","networkTimings":[52,145,149,0]}
2021-11-16T07:53:28.694Z <Debug> [140510316455680] TelemetryService.cpp:437 operator():Sent 1 events to prelogin metrics endpoint
2021-11-16T07:53:28.694Z <Debug> [140510316455680] HttpRequestManager.cpp:2600 _removeOutstandingRequest:requestId: 67834457-25d7-4d80-b4c7-d8669b3911ca, Outstanding HTTP requests: 0
2021-11-16T07:53:28.913Z <Debug> [140513344747264] Browser.cpp:883 OnLoadStart:Browser navigation starting: NativeWebAuthenticationWidget NativeWebAuthenticationWidget 9f44
2021-11-16T07:53:28.918Z <Debug> [140513344747264] Browser.cpp:894 OnLoadEnd:Browser navigation ending: NativeWebAuthenticationWidget NativeWebAuthenticationWidget 9f44 httpStatusCode: 200
2021-11-16T07:53:28.918Z <Debug> [140514400745280] NativeWindowUtils.cpp:60 setWindowSize:Set window size: w 1180 h 702
2021-11-16T07:53:28.919Z <Debug> [140514400745280] NativeWindowUtils.cpp:60 setWindowSize:Set window size: w 1179 h 702
2021-11-16T07:53:28.919Z <Debug> [140514400745280] NativeWebAuthenticationWidget.cpp:116 onLoadFinished:onLoadFinished: status code 200
2021-11-16T07:53:28.919Z <Debug> [140514400745280] Browser.cpp:528 getDocumentBody:getDocumentBody for:870b223c-9581-4ded-ac3f-124d75ef794a
2021-11-16T07:53:31.085Z <Debug> [140513344747264] Browser.cpp:883 OnLoadStart:Browser navigation starting: NativeWebAuthenticationWidget NativeWebAuthenticationWidget 9f44
2021-11-16T07:53:31.092Z <Debug> [140513344747264] Browser.cpp:894 OnLoadEnd:Browser navigation ending: NativeWebAuthenticationWidget NativeWebAuthenticationWidget 9f44 httpStatusCode: 401
2021-11-16T07:53:31.092Z <Debug> [140514400745280] NativeWindowUtils.cpp:60 setWindowSize:Set window size: w 1180 h 702
2021-11-16T07:53:31.092Z <Debug> [140514400745280] NativeWindowUtils.cpp:60 setWindowSize:Set window size: w 1179 h 702
2021-11-16T07:53:31.093Z <Debug> [140514400745280] NativeWebAuthenticationWidget.cpp:116 onLoadFinished:onLoadFinished: status code 401
2021-11-16T07:53:31.093Z <Debug> [140514400745280] NativeWebAuthenticationWidget.cpp:119 onLoadFinished:Page not loaded successfully. error: 401
2021-11-16T07:53:36.936Z <Debug> [140509242713856] StateMachine.h:155 operator():ConnectivityStateMachine::Network - NoNetwork -> NoNetworkAfterTimeout : {timeout}
2021-11-16T07:53:36.936Z <Debug> [140509242713856] StateMachine.h:119 _handleEvent:ConnectivityStateMachine::ConnectivityBanner - Connected -> NoNetwork : {NoNetworkAfterTimeout}
2021-11-16T07:53:36.936Z <Info> [140509242713856] ConnectivityBannerStateMachine.cpp:205 showBanner:ConnectivityStateMachine::ConnectivityBanner Showing Banner Text - 'No network connection'
2021-11-16T07:54:21.936Z <Debug> [140510819755776] StateMachine.h:155 operator():ConnectivityStateMachine::Mercury - Disconnected -> DisconnectedShortTerm : {timeout}
2021-11-16T07:54:21.936Z <Error> [140510819755776] FeatureSettingsManager.cpp:395 getSetting:Attempting to read value from DB before config store has been read. Key: desktop-conban-long-term-outage-wait
2021-11-16T07:54:21.936Z <Debug> [140510819755776] States.h:60 getTimeout:ConnectivityBannerStateMachine - Returning default timeout of 240seconds.
2021-11-16T07:54:21.936Z <Debug> [140510819755776] ServicesStateMachine.cpp:130 deriveNewState:ConnectivityStateMachine::Services [MercuryState:DisconnectedShortTerm] + [AuthState:UserAuthenticated] == [NewServicesState:DisconnectedShortTerm]
2021-11-16T07:54:21.936Z <Debug> [140510819755776] StateMachine.h:119 _handleEvent:ConnectivityStateMachine::Services - Connected -> DisconnectedShortTerm : {DisconnectedShortTerm}
2021-11-16T07:54:21.936Z <Debug> [140510819755776] StateMachine.h:106 _handleEvent:ConnectivityStateMachine::ConnectivityBanner - Unexpected event {ServicesDisconnectedShortTerm} for state [NoNetwork]
2021-11-16T07:54:24.114Z <Debug> [140514400745280] MainWindowNativeEventHandler.cpp:36 processNativeEvent:Got client message
2021-11-16T07:54:39.558Z <Debug> [140514400745280] MainWindowNativeEventHandler.cpp:36 processNativeEvent:Got client message
2021-11-16T07:54:39.559Z <Debug> [140514400745280] MainWindowNativeEventHandler.cpp:36 processNativeEvent:Got client message
2021-11-16T07:54:47.335Z <Debug> [140514400745280] MainWindowNativeEventHandler.cpp:36 processNativeEvent:Got client message
2021-11-16T07:55:42.308Z <Debug> [140514400745280] MainWindowNativeEventHandler.cpp:36 processNativeEvent:Got client message
2021-11-16T07:55:44.293Z <Debug> [140514400745280] MainWindowNativeEventHandler.cpp:36 processNativeEvent:Got client message
2021-11-16T07:56:14.368Z <Debug> [140514400745280] MainWindowNativeEventHandler.cpp:36 processNativeEvent:Got client message
2021-11-16T07:56:26.929Z <Debug> [140514400745280] MainWindowNativeEventHandler.cpp:36 processNativeEvent:Got client message
2021-11-16T07:56:28.680Z <Debug> [140514400745280] MainWindowNativeEventHandler.cpp:36 processNativeEvent:Got client message
Do you have set environment property http_proxy (or https_proxy or HTTP_PROXY,...) before running webex? It is needed when you are using proxy server.
gri_v
Just additional information.
In our company ADFS was switched to Microsoft Authenticator still occur, just with another error message
2021-09-07T09:26:07.426Z <Debug> [140278416926528] NativeWindowUtils.cpp:60 setWindowSize:Set window size: w 1179 h 702
2021-09-07T09:26:07.457Z <Debug> [140278416926528] NativeWebAuthenticationWidget.cpp:114 onLoadFinished:onLoadFinished: status code 200
2021-09-07T09:26:07.460Z <Debug> [140278416926528] Browser.cpp:510 getDocumentBody:getDocumentBody for:dbc5579e-0f5b-4e3e-b5c3-dea2374c9f93
2021-09-07T09:26:08.564Z <Debug> [140277496997632] CefClientHandler.cpp:579 OnCertificateError:Certificate Error: -202
2021-09-07T09:26:08.567Z <Debug> [140278416926528] NativeWebAuthenticationWidget.cpp:99 onCertificateError:Certificate Error
2021-09-07T09:26:08.574Z <Debug> [140277496997632] Browser.cpp:858 OnLoadError:Browser navigation error: NativeWebAuthenticationWidget Native
WebAuthenticationWidget b630 -3 ERR_ABORTED
Still not working inside company network and working fine outside. Tested on a versions 41.8.0.19732, 41.8.0.19868.
gri_v
Hi everybody,
I also have problem with ADFS, but only inside company network, from outside the App working fine. I tested versions 41.6.1.19162, 41.7.0.19440, 41.8.0.19732. According  Webex log file, it want to have NTLM
--- INSIDE
2021-08-11T08:46:07.291Z <Debug> [139720751224640] NativeWindowUtils.cpp:60 setWindowSize:Set window size: w 1180 h 702
2021-08-11T08:46:07.332Z <Debug> [139720751224640] NativeWindowUtils.cpp:60 setWindowSize:Set window size: w 1179 h 702
2021-08-11T08:46:07.371Z <Debug> [139720751224640] NativeWebAuthenticationWidget.cpp:114 onLoadFinished:onLoadFinished: status code 200
2021-08-11T08:46:07.379Z <Debug> [139720751224640] Browser.cpp:510 getDocumentBody:getDocumentBody for:363e67b3-efeb-4b32-8d98-9622ef2c630a
2021-08-11T08:46:08.175Z <Debug> [139719805294336] CefClientHandler.cpp:641 GetAuthCredentials:[GetAuthCredentials] Proxy:0, Scheme:ntlm
2021-08-11T08:46:14.252Z <Debug> [139720751224640] MainWindowNativeEventHandler.cpp:36 processNativeEvent:Got client message
2021-08-11T08:46:14.320Z <Debug> [139720751224640] MainWindowNativeEventHandler.cpp:36 processNativeEvent:Got client message
2021-08-11T08:46:14.322Z <Debug> [139720751224640] MainWindow.cpp:993 onExit:Exit requested
But outside ADFS authirization is working fine
--- OUTSIDE
2021-08-11T08:39:31.908Z <Debug> [139647340480320] NativeWindowUtils.cpp:60 setWindowSize:Set window size: w 1055 h 627
2021-08-11T08:39:31.909Z <Debug> [139647340480320] NativeWindowUtils.cpp:60 setWindowSize:Set window size: w 1054 h 627
2021-08-11T08:39:31.909Z <Debug> [139647340480320] NativeWebAuthenticationWidget.cpp:114 onLoadFinished:onLoadFinished: status code 200
2021-08-11T08:39:31.909Z <Debug> [139647340480320] Browser.cpp:510 getDocumentBody:getDocumentBody for:e5cc571f-f0c2-47ec-af03-2a587a044363
2021-08-11T08:39:41.351Z <Debug> [139647340480320] MainWindowNativeEventHandler.cpp:36 processNativeEvent:Got client message
2021-08-11T08:39:44.391Z <Debug> [139647340480320] MainWindowNativeEventHandler.cpp:36 processNativeEvent:Got client message
2021-08-11T08:39:48.191Z <Debug> [139647340480320] MainWindowNativeEventHandler.cpp:36 processNativeEvent:Got client message
2021-08-11T08:40:02.000Z <Debug> [139643940955904] StateMachine.h:155 operator():ConnectivityStateMachine::Mercury - Disconnected -> DisconnectedShortTerm : {timeout}
2021-08-11T08:40:02.000Z <Error> [139643940955904] FeatureSettingsManager.cpp:352 getSetting:Attempting to read value from DB before config store has been read. Key: desktop-conban-long-term-outage-wait
2021-08-11T08:40:02.000Z <Debug> [139643940955904] States.h:60 getTimeout:ConnectivityBannerStateMachine - Returning default timeout of 240seconds.
2021-08-11T08:40:02.000Z <Debug> [139643940955904] ServicesStateMachine.cpp:130 deriveNewState:ConnectivityStateMachine::Services [MercuryState:DisconnectedShortTerm] + [AuthState:UserAuthenticated] == [NewServicesState:DisconnectedShortTerm]
2021-08-11T08:40:02.000Z <Debug> [139643940955904] StateMachine.h:119 _handleEvent:ConnectivityStateMachine::Services - Connected -> DisconnectedShortTerm : {DisconnectedShortTerm}
2021-08-11T08:40:02.000Z <Debug> [139643940955904] StateMachine.h:106 _handleEvent:ConnectivityStateMachine::ConnectivityBanner - Unexpected event {ServicesDisconnectedShortTerm} for state [NoNetwork]
2021-08-11T08:41:10.143Z <Debug> [139647340480320] MainWindowNativeEventHandler.cpp:36 processNativeEvent:Got client message
2021-08-11T08:41:10.215Z <Debug> [139647340480320] MainWindowNativeEventHandler.cpp:36 processNativeEvent:Got client message
2021-08-11T08:41:10.215Z <Debug> [139647340480320] MainWindow.cpp:993 onExit:Exit requested
2021-08-11T08:41:10.215Z <Debug> [139647340480320] AsyncCloseWidgets.h:51 requestClose:MainWindow|MainWindowClass notifying CefQt::CefQWidget|CefQWidget
2021-08-11T08:41:10.215Z <Debug> [139647340480320] Browser.cpp:239 closeBrowser:CEF Browser Async close requested
2021-08-11T08:41:10.215Z <Debug> [139646415656704] CefClientHandler.cpp:344 DoClose:Client handler DoClose
2021-08-11T08:41:10.216Z <Debug> [139646415656704] CefClientHandler.cpp:360 OnBeforeClose:Client handler OnBeforeClose
2021-08-11T08:41:10.216Z <Debug> [139646415656704] Browser.cpp:659 OnBrowserClosed:Browser closing: NativeWebAuthenticationWidget NativeWebAuthenticationWidget 367b
2021-08-11T08:41:10.216Z <Debug> [139646415656704] Browser.cpp:687 OnBrowserClosed:Firing close complete callback.
2021-08-11T08:41:10.216Z <Debug> [139646415656704] AsyncCloseWidgets.h:118 onListenerCompleted:MainWindow|MainWindowClass - Listeners completed.
2021-08-11T08:41:10.216Z <Debug> [139646415656704] MainWindow.cpp:1007 doClose:Do Exit
May be something have to be done in configuration of company ADFS server, but I don't have access for administration.
Vasiliy
But how can I collect these logs under linux? I can't choose the Active Directory/ADFS option to to complete the authentication procedure therefore I can't access the GUI ...
in my case, logs collected in a folder /run/tmp/home/notouchusr/.local/share/Webex, file current_log.txt
When I start App - Accept - input my company e-mail - Enter - and nothing just white window.
Application is working according a log, checking metrix, my license, my connection server https://u2c.wbx2.com. After that it forward me to adfs.mycompany server and drop connection, but have to be window with authorization.
I have huge collection of logs and wireshark tcpdump files, from inside and outside, with proxy inside and no proxy. Every time white window when inside the company, and working fine outside the company.
when I working inside over browser, than ADFS workng.I think something wrong inside Application, NTLM authentication is working fine in Webex Teams under Windows, not necessary to input ADFS credencial, but under Linux  NTLM is not supported and Application have to ask me for authorization.
I've also tried to install and use Webex v41.5.0.18815 on my Debian, Ubuntu and RHEL machines.
On Debian 10.9 (4.19.181-1) X86_64 Webex is not opening. But I understand that Debian isn't on the list of the officially supported distros (this is the first time, in my personal experience, that a software intended for a Debian-based distribution does not work on ... Debian!)
On Ubuntu 20.04.2 LTS (5.8.0-53) X86_64 Webex starts up regularly but once I enter my company e-mail, Webex redirect me to our SSO page and the web page elements are not clickable ... therefore I can't choose the Active Directory/ADFS option to to complete the authentication procedure.
On Red Hat Enterprise Linux 8.4 (4.18.0-305.el8) X86_64 Webex starts up regularly but once I enter my company e-mail, Webex redirect me to our SSO page and the web page elements are not clickable ... therefore I can't choose the Active Directory/ADFS option to to complete the authentication procedure (same as Ubuntu).
UPDATE June 23 2021: nothing's changed with the current release ((41.6.1.19162-1)
You can use Webex in Debian 10 if you upgrade the kernel using buster-backports.
James Grogan
You can check your version of Red Hat for compatibility, at the moment version 8 only is supported: https://help.webex.com/en-us/9vstcdb/Webex-for-Linux
Otherwise failure to start is often due to a missing dependency/conflict. You can check with:
ldd /opt/Webex/lib/libspark-windows-desktop-ui.so
ldd /opt/Webex/lib/plugins/platforms/libqxcb.so
for the most common cases.
We are working to improve user feedback when the app fails to launch due to runtime dependency issues.
James
