Recording Simultaneous Interpretation audio channels, Interpreter Vid
emajcic
Hi Cisco team,
Thankyou for this feature. It will be very useful for our users.
Have been testing this feature using webex meetings and noticed the following;
Interpreter Audio channels are not recorded, only the main audio channel. If this the desired operation? Recording the language audio channels would be good for validation and record keeping.
Also, I understood that interpreter video is off by default. That is, the interpreter video is disabled. However, I found that interpreter video is enabled and interpreter visible. Interpreter can control their own video.
Appreciate Cisco experts confirm this is correct operation or otherwise.
Maksym Kozub
I support your request for language channels recording feature. Would you submit it to https://ciscocollabcustomer.ideas.aha.io/?
With regard to your second point, my understanding is that in terms of video, interpreters are treated like other meeting participants, and I would say this is logical. I.e., whatever the meeting organizer, host, etc. decides on whether participants should have their video off or on by default, whether they should be able to switch it on and off on their own, etc. applies to interpreters, too.
