WebEx crash
Opale Solutions
Many of WebEx app on out compagny computers crash since 1 week.
The EventViewer shows a DLL (.Net) Issue (error below).
We tried reinstall WebEx completely after removing completely the %appdata% folders.
Update Windows 10. Upgrade Windows 10 to last version 22h2. Notging helps.
Nom de l’application défaillante CiscoCollabHost.exe, version : 1.0.0.2, horodatage : 0x65710f2a
Nom du module défaillant : ntdll.dll, version : 10.0.19041.2788, horodatage : 0x2f715b17
Code d’exception : 0xc00000fd
Décalage d’erreur : 0x000000000002b27b
ID du processus défaillant : 0x576c
Heure de début de l’application défaillante : 0x01da2dd419add5b0
Chemin d’accès de l’application défaillante : C:\Users\AUMA\AppData\Local\Programs\Cisco Spark\CiscoCollabHost.exe
Chemin d’accès du module défaillant: C:\WINDOWS\SYSTEM32\ntdll.dll
ID de rapport : 831ec54b-229b-46d2-9391-d2ada9c7b3ec
Nom complet du package défaillant :
ID de l’application relative au package défaillant :
Jonathan Schulenberg
One week ago was the December 42.12 release. Open a TAC case and make them identify the bug. In the meantime they may need to help you roll back to 42.11 if a fix cannot be readily identified.
Blue_Bird
Hello Opale Solutions,
This issue may occur due to high resource consumption. Examples like: Excessive usage of Ram/Processor causes the machine to freeze or crash.
Here are the Troubleshooting Tips:
  1. Is your device compliant with the Webex system requirements?
  2. Can the issue be replicated while using the Web App? Get started with the Webex Meetings web app.
  3. Uninstall the meeting application. Run the Meeting Services Removal Tool or Mac Cisco Webex Uninstaller.
    • Manually download the Meeting / Event / Training application from the site where the user is trying to start or join the meeting. Open your Webex site URL (example: SITENAME.webex.com) and go to Download.
  • Contact local IT for assistance if the user needs administrative privileges to install the program.
  1. Try on a separate device connected to the same network.
    • If the problem happens on another device, try a different platform on the same network (for example, macOS, Windows 10/11, mobile OS).
    • Try it on a different network (for example, connect your device to a mobile hotspot or router).
      • If the problem is network-related, contact your local IT and share these articles: WBX264 / WBX000028782.
  2. Check that your graphic, camera, and audio drivers are all up to date: Cisco Webex and 3rd Party Support Utilities.
  • Contact your local IT department or the computer manufacturer for assistance in upgrading the drivers.
  • Check if any security software is installed on the machine that is creating this problem.
    • Whether feasible, deactivate it momentarily to see if the problem remains.
Reference: https://help.webex.com/en-us/article/WBX9000036495/Troubleshooting-Common-Issues:-Webex-Meeting-Application-Crashing-/-NetworkDisconnects
Best regards
******* If This Helps, Please Rate *******
