02-17-2022 06:42 AM
Jabber has a floating icon that attaches to the desktop. We recently moved from Jabber to Webex and there seems to be no floating icon/mini webex as there was with jabber. Has anyone been able to figure this out?
02-17-2022 07:36 AM
Not exactly the same try CTRL + SHIFT + X and then same again to remove. Sits on the task bar. Found also on the menu called Quick Call under Settings | Calling in the Webex App.
02-18-2022 11:35 AM
This solution did not work. Ctrl + Shift + X while in the new webex app does not do anything. I also have nothing in settings call quick call.
