06-11-2020 12:14 AM
Hi everyone,
I have a problem recording video file. I mean, when the meeting ends, webex automatically creates a video (mp4) file, but when I play the video, the resolution is low, seems to be something like 360p or 480p, not 720p that the file could be (even if looking into file properties the resolution is 1280x720).
I use a professional reflex as webcam, so the signal I send is probably at 1080p. I'm using a free account at the moment.
Any suggestion?
Thanks in advance
03-16-2021 02:22 PM
@onolilath
There are 2 recording-options: to the cloud and to the local computer.
As far as I understand, Cisco could only interfere with cloud-recordings.
Based in this table, the free account does not offer cloud-recordings: https://www.webex.com/pricing/index.html
(perhaps Cisco did not disable this feature, but limit the quality?)
((similar to the limitation of max. meeting-duration: 50 minutes does not seem to apply to 1:1 meetings..))
During my tests, local recordings worked very good.
Is your computer capable to handle both at the same time? the Webex-Meeting and recording(encoding) the Content?
08-20-2021 07:51 AM
My recent Webex recording was only set to 768p only and mono.
It looks really bad when doing post-edit in DaVinci Resolve.
06-11-2020 04:46 AM
06-11-2020 05:14 AM
The video that I see on screen is hi-res; instead the mp4 file is in low-res.
I can't guess why.
03-16-2021 06:43 AM
I'm having the same issue which is quite frustrating. The call quality is 720p and is very sharp but getting weird compression on recordings and the quality seems super low even though the file is 720p. From time to time the screen flashes and the image gets super soft and slowly calibrates itself back.
