Webex Meetings Scheduled Through Outlook Issue
Chase McFadden
Running into an issue where reoccurring Webex meetings scheduled through Microsoft Outlook are displaying another instance of the host's name in the meeting title to each future occurrence of the meeting. Picture attached for better clarification.InkedStrangeGlitch.jpg
dtibbe
I had never observed that in the past for my recurring meetings..
Is it just for that specific meeting series or does it reoccur for another series as well?
Multiple series of meetings on the Webex room kits calendar. But if you look at the user who set up the meetings personal calendar the meeting titles appear normal.
Does it also occur if you invite the room without adding a meeting (assuming you're using some kind of hybrid calendar integration)? If so, then Webex may not be the cause of the issue..
Otherwise, I'd suggest to raise a TAC case, they may check some logs..
