Webex Meetings Starter, Plus and Business plans with more participants?
Piotr_Rzepecki
Good morning Everyone.
Is it a way to have for example Starter / Plus or Business plan(s) with more than 100 participants?
Let us say if I would like to have 4 hosts, so Starter plan could be enough,
but I would like also host more than 100 participants.
Best Regards.
Piotr Rzepecki
Thank you for your suggestion.
Fritz_H
@Piotr_Rzepecki
I guess, you have already checked the standard Plans & Pricing - Table here: https://www.webex.com/pricing/index.html ?
You may either go for the license-levels "Business" or "Enterprise" or contact your local Cisco-Partner.
https://locatr.cloudapps.cisco.com/WWChannels/LOCATR/openBasicSearch.do
I have experienced, that they have several options to tailor the package according to your needs.
Yes, I have already checked standard Plans & Pricing, so I was wondering if there is some kind of add-on,
which could be added to purchased plan to extend number of participants.
@Piotr_Rzepecki
I see.
As I already suggested:
please contact a local Cisco-Partner; there are more licensing-options available than shown on the Cisco-Webpage..
