How to silence WebEx Meetings on iPad
Denis74906
I'm using an iPad as a second screen (or second login) on my WebEx meeting. This allows me to see what I'm sharing with the participants as seen by the other participants. Somehow I cannot completely silence the WebEx Meetings session on my iPad. Am I missing something, or is this simply not possible?
RedNectar
Hi @Denis74906 ,
On your iPad, touch the elipsis (...) and choose Change Audio Connection
This gives you an option Don't Connect Audio
Your strategy of using the iPad to see what is being seen is far better than the rather annoying drop-down thing that gets in the road when you are sharing a screen.
I hope this helps.
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem.
RedNectar aka Chris Welsh.
RedNectar
Hi @Denis74906 ,
I hope this helps.
Fritz_H
@Denis74906
Do you really still need this work-around?
In June 2020 Cisco announced this feature: https://www.youtube.com/watch?v=ipkYcVEILuY
It is already available in Webex-Meetings, but not (yet?) in Webex(-Teams).
