Call Log View
Laural Beaty
Community Member
My company just upgraded to the new Webex app. The call log is always open, is there a way to hide it when I'm not using it?
Thank you for your assistance.
Laural Beaty
Stephanie Knoop
The call log will always be visible as a menu item on the left hand pane as a part of the calling tab. This allows you to redial, callback, etc.  However, it is only visible when you are in the calling context.
Response Signature
