Chris
CFunke
Community Member
I can't be heard in unmute?
Matt_W
Level 8
Level 8
There are a number of things you could check.  Make certain your audio device selected is the microphone you want to use.  If you are using the web version, make certain the browser is not blocking your audio.
Webex Audio Troubleshooting
