Renewing Webex Certification
stevenha1
Frequent Visitor
Frequent Visitor
Hello.  I was informed that my certification for the Webex Ambassador Power User is going to expire.  I only see one training that I have already taken under Certifications & Retraining (see attached pic).  Is retaking the "Webex Ambassador Power- User - Final Test" the path I should take to renew my certification?
Cole Callahan
Yes, click on that. And then you can select the test button to retest
Response Signature
5 Replies 5
NIT PATNA
Community Member
how to renew subscription for webex for one year with 1000 participants.
Cole Callahan
Response Signature
Thanks!  I'll give it a try next week.
Cole Callahan
Hi @stevenha1 ,
If you already completed that level of Ambassadors in the past, then you will only be required to retest for it rather than go through all the modules again, if you wish. You can recertify early if you would like. I just did it moments ago to test the functionality, and now my Ambassadorship and Credly badge are valid through 07/2023.
Response Signature
Cole,
Thanks for the quick reply!  To recertify do I just click on the player of the item listed in the attached screen capture?
