05-07-2021 05:27 AM
Hi all,
I added at least 2 questions to a registration and while the even hadn't happened, the questions showed up in the registration form. However when I downloaded the report, the questions had disappeared from the report and I was unable to pull any info. Is there any way to retrieve the original registration questions? I need the data for a report.
Thank you,
Robin
05-07-2021 12:38 PM
Pull your event attendance report, they usually have the custom questions that were on the registration form. Once you've signed into your Webex site, click on your name in the top right, then chose Reports, then scroll to the Webex Events reports section.
05-07-2021 10:45 PM
05-10-2021 04:06 PM
I tested it out and was not able to re-create the issue you are having. I was able to access custom questions in my report. When I tested I removed all the standard questions. So this makes me wonder ... Could there be a limitation on how many questions can be visible in the report. How many questions are on your registration form?
