10-16-2020 06:55 AM
Hey guys, do you know where I can find reports for Webex Events now that the interface for setting up an event has been updated? In the past, you could access it in the "My Webex" menu but that doesn't exist anymore, so where do I find the reports now? Thanks so much for your help in advance!
Solved! Go to Solution.
10-16-2020 09:29 AM
@archie_flip , you can acccess your reports by clicking on your name at the top and right and then select "My reports":
10-16-2020 09:29 AM
06-28-2021 11:08 PM
//meetingsapac46.webex.com/ in this option, above problem is solved as the same screen is appeared with "My reports" option.
But //meet20.webex.com/ in this option, the option "My reports" is not there then how to solve same problem of taking reports.
