ap802 - error % QOS Policy-maps configuration is not supported
Luca Pecchiari
Hello i am trying to configure a policy map, but when i run the command i get:
ap(config)#policy-map test
now i am on release ap802-k9w7-mx.153-3.JF12 with a router C887VA-WD-E-K9 (tryed also different build with this relase , but no onw work.)
Instated the command was working on the: ap802-k9w7-tar.124-25d.JAX1.tar
Do you have any ideas why policy map does not work?
Thank you.
0 Replies 0
