Vinay Sharma
Level 7
Level 7
Introduction
Configuring Autonomous AP for Local RADIUS Authentication
Setting the AP as local RADIUS server
1. Go to Security>Local RADIUS Server>General Setup
2. Enable Authentication Protocols (EAP FAST,LEAP and MAC)
3. Click on Apply
4. Specify the IP address of the RADIUS (the AP's IP)
5. Specify a shared secret password
6. Click on Apply
7. Create usernames/password on the RADIUS
8. click on Apply.
Defining the Authentication Server
1. Go to Security > Server Manager
2. Enter the IP address of the authentication server in the Server field
3. Specify the Shared Secret and the ports (optional)
---> authentication port = 1812 if local Radius
4. Specify the shared secret password
5. Click Apply
6. Under Default Server Priorities, set the EAP Authentication type Priority 1 field to the Radius server IP address (AP IP)
7. Click Apply
Note
Once the access point knows where to send client authentication requests, configure it to accept those methods:
Configuring AP
1. Go to Security>Encryption Manager
2. Specify Encryption (can be WEP or WPA)
3. Specify that WEP is Mandatory
4. Specify the key accordingly
5. Click Apply
6. Go to Security>SSID Manager
7. Select the desired SSID
8. Under Authentication Settings> Methods Accepted, select the following:
---> Open Authentication (with EAP)
---> Network-EAP( no addition )
8b. Under Client Authenticated Key Management
---> Key Management: Mandatory
---> Enable WPA: Checked (with WPA drop down)
9. Click Apply.
10. Specify the IP address of the Radius server under EAP Authentication
11. Click Apply.
Reference
Configuration Examples and TechNotes
Gabe1918
I tried configuring these on the Aironet 1700 access point not working, The client cannot connect with the username and password. Just wondering have you test-configured the access point in 1700 before?
