ritchauh
Introduction:-
Example of a repeater AP communicating with a root  AP using LEAP with local RADIUS server.
Configuration Example:-
------------->>>>>>>>>>>>>>>>>>Root AP config <<<<<<<<<<<<<----------------
sh run
Building configuration...
Current configuration : 2065 bytes
version 12.3
no service pad
service password-encryption
hostname ROOT
enable secret 5 $1$JN3t$3P2WtEwUd8F9Q6PCy12WT0
led display alternate
ip subnet-zero
aaa new-model
aaa group server radius rad_eap                             <<<We are defining a group rad_eap and specifying the IP of the RADIUS server
        <<<This AP is acting as the local RADIUS server
server 192.168.1.1 auth-port 1812 acct-port 1813
aaa authentication login eap_methods group rad_eap           <<<For rad_eap group, method to be used is eap_methods
aaa session-id common
dot11 ssid test                                                       <<<test SSID used for communication between the parent AP and the repeater AP
   authentication open eap eap_methods
   authentication network-eap eap_methods
   infrastructure-ssid
power inline negotiation prestandard source
username Cisco password 7 112A1016141D
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid test
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
dfs band 3 block
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
channel dfs
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
radius-server local        <<<<<<<local RADIUS server config
  nas 192.168.1.1 key 7 03105E1812
  user test nthash 7 101E2A3B534E465354547F0D737164170441264E5159060E0104072C5B41430A0F   <<<You need to define same username/password on the repeater AP also
radius-server host 192.168.1.1 auth-port 1812 acct-port 1813 key 7 0010161510      <<<<<<<<<<We are telling this AP to communicate with server 192.168.1.1
        <<<<<<( this AP itself) using the mentioned key
control-plane
bridge 1 route ip
line con 0
line vty 0 4
end
------------>>>>>>>>>>>>>Repeater AP<<<<<<<<<<<<<<<-------------
Current configuration : 1879 bytes
version 12.3
no service pad
hostname NON_ROOT
enable secret 5 $1$reJk$pTPrQFJU2M7TWqhxUy3/o/
ip subnet-zero
aaa new-model
server 192.168.1.1 auth-port 1645 acct-port 1646                <<<for repeater AP, parent AP is the server
dot11 ssid test
   authentication client username test password 7 105A0C0A11  <<<defining username/password already configured on the parent AP ( under local radius server config mode)
   infrastructure-ssid
username Cisco password 7 096F471A1A0A
bridge irb
no ip address
no ip route-cache
ssid test
54.0
station-role repeater
bridge-group 1
no ip address
no ip route-cache
shutdown
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address 192.168.1.2 255.255.255.0
no ip route-cache
ip http server
control-plane
bridge 1 route ip
Related Documents:-
LEAP Authentication on a Local RADIUS Server
Configuring Repeater and Standby Access Points
Vinay Sharma
Level 7
Level 7
Nice configuration example. thanks for sharing.
