TCC_2
Level 10
Level 10
Resolution
This error message indicates that the update process (upgradaging from VxWorks to Cisco IOS ) is not completed because of low memory in the device. The memory is low due to the loading of the huge .ini file that takes place with the Download All System Configuration option.
The upgrade process may not be successful if the non-Cisco IOS Access Point (AP) has the configuration loaded with the .ini file that was acquired through Download All System Configuration option. Use the .ini file from the Download Non-Default System Configuration option.
For more information, refer to the System Requirements section of Release Notes for Cisco Aironet Conversion Upgrade Image 3.0 for Cisco IOS Software.
Problem Type
Error message
Products
Access point
Security Options
WEP key
VxWorks Errors, Warnings, Statistics and Log Messages
WEP Default Key set error 2
