Nicolas Darchis
Association response reason code :
Reason code field:
As you can see, some codes are irrelevant for an association response. That is because the reason code field has the same meaning wherever it is used (disassociation frames, …)
Status
Meaning
Success
Unspecified failure
2-9
Reserved
Cannot support all requested capabilities in the Capability Information field
11
Reassociation denied due to inability to confirm that association exists
12
Association denied due to reason outside the scope of this standard
13
Responding STA does not support the specified authentication algorithm
14
Received an Authentication frame with authentication transaction sequence number out of expected sequence
15
Authentication rejected because of challenge failure
16
Authentication rejected due to timeout waiting for next frame in sequence
17
Association denied because AP is unable to handle additional associated STAs
18
Association denied due to requesting STA not supporting all of the data rates in the
BSSBasicRateSet parameter
19
Association denied due to requesting STA not supporting the short preamble option
20
Association denied due to requesting STA not supporting the PBCC modulation option
21
Association denied due to requesting STA not supporting the Channel Agility option
22
Association request rejected because Spectrum Management capability is required
23
Association request rejected because the information in the Power Capability element is unacceptable
24
Association request rejected because the information in the Supported Channels element is unacceptable
25
Association denied due to requesting STA not supporting the Short Slot Time option
26
Association denied due to requesting STA not supporting the DSSS-OFDM option
27-31
Reserved
32
Unspecified, QoS-related failure
33
Association denied because QoS AP has insufficient bandwidth to handle another QoS STA
34
Association denied due to excessive frame loss rates and/or poor conditions on current operating channel
35
Association (with QoS BSS) denied because the requesting STA does not support the QoS facility
36
Reserved
37
The request has been declined
38
The request has not been successful as one or more parameters have invalid values
39
The TS has not been created because the request cannot be honored; however, a suggested TSPEC is provided so that the initiating STA may attempt to set another TS with the suggested changes to the TSPEC
40
Invalid information element, i.e., an information element defined in this standard for which the content does not meet the specifications in Clause 7
41
Invalid group cipher
42
Invalid pairwise cipher
43
Invalid AKMP
44
Unsupported RSN information element version
45
Invalid RSN information element capabilities
46
Cipher suite rejected because of security policy
47
The TS has not been created; however, the HC may be capable of creating a TS, in response to a request, after the time indicated in the TS Delay element
48
Direct link is not allowed in the BSS by policy
49
The Destination STA is not present within this BSS
50
The Destination STA is not a QoS STA
51
Association denied because the ListenInterval is too large
And for authentication frame :
As you can see, some codes are irrelevant for an association response. That is because the reason code field has the same meaning wherever it is used (deauthentication frames, …)
Reason code
Meaning
Unspecified reason
Previous authentication no longer valid
Deauthenticated because station leaving BSS/ESS
Disassociated due to inactivity
Disassociated because AP unable to handle all currently associated stations
6
Class 2 frame received from non authenticated station
7
Class 3 frame received from non associated station
8
Diassociated because station leaving BSS/ESS
9
Station requesting (re)association is not associated with the responding station.
Diassociated because the information in the power capability element is unacceptable
11
Disassociated because the information in the supported channels element in unacceptable
12
Reserved
13
Invalid information element (not matching standard format)
14
MIC failure
15
4-way handshake timeout
16
Group key handshake timeout
17
Information element in 4 way handshake different from association request/probe response/beacon element
18
19
20
Invalid AKMP
21
Unsupported RSN information element version number
22
23
802.1x authentication failed
24
25-31
Reserved
32
Diassociated for unspecified QoS related reason
33
Disassociated because QoS AP lacks sufficient bandwidth for QoS station
34
Disassociated because excessive number of frames need to be acknowledged, but are not acknowledged due to AP transmissions and/or poor channel conditions
35
Disassociated because STA is transmitting outside the limits of its TXOPs
36
Requested from peer STA as the STA is leaving the BSS (or resetting)
37
Requested from peer STA as it does not want to use the mechanism
38
Requested from peer STA as the STA received frames using the mechanism for which a setup is required
39
Requested from peer station due to timeout
45
Peer station does not support the cipher suite
Supermantech
good reference, thanks
