TCC_2
Level 10
Level 10
Resolution
The Wireless LAN Controller (WLC) acts as a Dynamic Host Configuration Protocol (DHCP) relay device. The WLC does the DHCP relay through the virtual interface. Typically, the 1.1.1.1 address is assigned to the virtual interface. This address can be any address. However, it must not be a routable address.
This is the sequence of events that occur:
  1. The WLAN client sees the administration-defined virtual address as the DHCP server address. The recommended address is usually 1.1.1.1 because this address is not normally a routable network address.
  2. The WLC shows the virtual address to the WLAN clients and the management interface address upstream.
  3. The WLC acts as a DHCP relay (Bootstrap Protocol [BOOTP] relay) device.
Note: When the internal DHCP server is used, the lightweight access point (LAP) must be directly connected to the WLC. Also, a DHCP scope cannot be shared between two or more WLCs.
Note: If you run a DHCP server on a PIX 501, the PIX does not support DHCP requests from a relay agent, which is how the WLC sends the request. You also need to configure a DHCP scope internal to the controller and remove DHCP override from the WLAN.
For more information on how to troubleshoot WLC, refer to Wireless LAN Controller (WLC) Troubleshoot FAQ
For more information about the WLC, refer to Cisco Wireless LAN Controllers.
For more information on configuring DHCP, refer to the Configuring DHCP section of Configuring Security Solutions.
Problem Type
Configure / Configuration issues
Associated but cannot pass any traffic
Release notes / product  overview / data sheet / FAQ
Technical product specification / features
Products
IP Address Assignment
Dynamic addressing (DHCP)
