Rob Johnson
    Introduction
    Steps to Install Update Patch for Prime Infrastructure 2.0
    Download the Prime 2.0 patch
    Extract the .UBF file from the zipped archive
    and save it to your desktop for example
    Login to your Prime Server as the root user
    Go to Administration> Software Update
    Upload Update File
    Select the Option to Upload Update File
    Install Software updates
    Once the Update file has been loaded, you'll need to select it with a Check Box then click Install button
    Restart NCS
    You'll see below a Restart of NCS is required
    Stop NCS services
    Start NCS services
    More information
    Release Notes for Cisco Prime Infrastructure, Release 2.0
    Cisco Prime Infrastructure 1.3 Deployment Guide
    rafafilho11
    For Cisco Prime Infraestructure HA Update path or device patch.
    The same process as standalone to upgrade ? or I'll need to broken the HA pairs and update one by one ? and after that re-create the HA pairs.
    rafafilho11
    Cisco Prime Infraestructure HA high availability update path
    First Break HA from the primary device;
    Administration / Settings / High Availability
    Remove
    Update the path in the primary device;
    Go to Adminstrator => Software Update
    Access Secondary and also update the path (https://x.x.x.x:8082)
    From the primary Server Configure High Availability again; In order to finish configuration successfully will be need both servers configured with the same version and patches.
    ttps://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-1/administrator/guide/PIAdminBook/config_HA.pdf
